1 - 10 of 10 Posts
I'm looking to replace one or both of the DSC brake pressure sensors on a 2004 320d E46. Are there any non-BMW parts recommended?
Ebay has lots of cheaper alternatives, does anyone have a known good supplier (ebay or otherwise), and not one of the Chinese copy parts?
If they are very expensive then i would first try a used one but never a Chinese copy.
Chinese copy is a no go. I was hoping for someone that has used "x" brand or seller a few times for good parts.
I think they are about £60-£70 each, but the car needs a few other expensive parts to get it through the MOT. If it has to be BMW then it has to be, I know for some parts on other cars I've always go OEM (or bosch etc directly).
Vendor
New from the dealers they are around £100-£115 each I think from what I can remember
BW chiptune
Tuning BMWs since 1991
Dyno Dynamics rolling road.
BW autorepairs
Over 30 year repairing BMWs.
New and fully refurbished BMW/Alpina ,Ecus (DME,DDE)and Cas units.
BMW Ecu repairs.
Key data fixed for non starters or when theft attempted.
UK
0208 561 1818
07831 103030
Hayes
UB3 1BB
or
Spain
Orihuela Costa
+447831103030
i put abs sensor from bavarian dominator(e46 330d),,well i did then they phoned to say out of stock,,so they put a one fronm ebay for me from another seller,,fitted,,worked fine ,sold the car now but worked fine. £25,i could put the seller on link,,is this the same sensor your talking about ?
I bought a fleabay alternative 2 years ago for 40 quid. Bosch equivalent was well over 100. Anyway, the pattern part has been fine ever since, meanwhile the other original pressure sensor is still going strong at 15 years old!
Having said that, I once bought a low cost front disc and pad set from a fleabay shop, the quality was appalling. Poor stopping force then one disc warped within a few months. Replaced with textar pads & mintex discs, difference was night and day.
In terms of quality there's always a small risk with low cost pattern parts, in my experience.
1 - 10 of 10 Posts
