I suspect my piston rings are worn because I use a lot of oil (1 litre per 400-500 miles) and the car occasionally smokes on startup. I don’t want to go down the route of an engine rebuild or engine swap. My question is what oil should I change to and what brand? Also since the car uses so much oil anyway, should I skip the oil change and just stick to changing the oil filter instead?
You can run it on 5w40 if you are not already doing so?
Have you replaced the CCV? When faulty these can cause excessive oil usage
