1 - 9 of 9 Posts
I have a problem thats intermittent I lock the car return the next morning unlock the car with the remote try to start it and just get the clicking and flashing lights hook up to a spare battery and it starts on the button drive 2 miles to work and park up when i return after work it starts no problem. the battery is less than a year old this has now happened 3 times in the last 4 months when the engines running the battery shows around 13.5/14v with the engine off it shows 11.75 ish the car seems to go to sleep ok ie the P light on the autoshift is off can anyone shed any light on the problem?
sounds like a dodgy battery to me, a fully charged battery should show 12.7v or very close to. yours is no where near where it should be. might be worth charging it with a good charger if you have one.
You might be using all the power in the batt on your short journeys that the alternator cant replace in time.
It is colder of a night which takes its toll on a low charged batt.
its been ok on the few days we've had a frost but has failed on not so cold nights its a good quality bosch battery and if it was due to the low mileage I do to work surely it would happen more often
11.75volts in a battery is somewhere around 25% charged, a very flat battery. 12.6 is about 90% charged. i would give it a top up on a good charger (dont rely on the car doing it) then leave it for a while to settle and then recheck the voltage. a drop tester would also help to see how good the battery is. it could be a faulty one.
ok dont know if this will help anyone to diagnose my problem today i was in a queue to get the car washed the heater was set to auto and i noticed the fan speed go up and down a few times i have not noticed this before is it supposed to do this?
ok thanks i will try this
1 - 9 of 9 Posts
