Hi everyone,
Firstly I'm not a major fan of the facelift lights plus this cost me very little with just new adjusters (fitted last year), the ring kit also last year and a small sheet of aluminium 250mm x 500mm all for about 30 squid.
Thought I'd update and show pictures of what I've modded to make it all a nice fit and keep the standard wiring with the rings. Rings are fitted to the outside of the glass otherwise they are not crisp enough, support bracket between each ring has been removed and on the rear of the rings there was plastic/metal clamps to hold the ring together, these have all been cut and modded so the ring can be fitted dead flush on the glass, can't see how the rings are fitted at all from the outside.
Next was some sort of projector shroud so the low beam ring can be seen perfect when the lights are on, also cover the side light hole and make 2 identical cutoff shields. I would prefer 2 originals as in post #1, but the 2 I made match perfect, (very difficult to keep the cutoff perfectly even and flat with a fine file and go slow, very good results can be acheived).
It fits the housing perfect, does not rub on anything throughout any adjustment at any point.
Also still working is the adjuster to flatten the beam pattern if I drive abroad, with a little modding and a grommit it works and doesn't leak any light out.
Here it is finshed and I can say the beam pattern projected is perfect and just like any other xenon, if I was super fussy it needs auto leveling for the perfect setup and to be legal :rofl
I hope these picture uploads work as it took me a while to sort this haha,
Hope it helps someone out.
