Hi all,
New member here and there is some great advise on here too. I have read through much of the forum already but don't seem to be able to fix my problem.
Within a few days a number of electrical gremlins have appeared which seem to indicate the ign switch.
Indicators often don't show inside car or make the clicking noise.
When indicators do work inside they carry on flashing inside of car for 10 sec after switching off (The actual lights outside switch off)
Loose CD player function on stereo
Heated seats intermittent
Air con intermittent
Steering wheel volume controls intermittent
Sometimes steering wheel doesn't come down when ignition is turned
Sometime the car wont lock on the key
Once, the alarm went off when it did lock
Once, it didn't turn over when trying to start
Once, the wipers nor jets worked
After searching and reading on here everything pointed to the ignition switch so I replaced that with high expectations. However it doesnt seem to have made any difference. Ive left the battery off overnight and no difference.
Any further ideas as to the issue? Last week everything worked just fine, its so irritating!
Are they that sensitive? It always starts on the button and wouldn't give me any thinking that it was on its way out. Does anyone know some suspectible Earth points perhaps?
