G
Guest
·Hiya chaps, while crawling in traffic the other day (for nearly an hour) my tempreture gauge started heading for the red. I switched the car off before it hit the red mark so it didnt implode/explode on me. I did 250 miles after that and it was absolutely fine and never went above the half way mark.
The fan is definately working properly and it cant be stopped with a paper or anything. Also no water and coolant have mixed and it runs fine so Im doubting its the head. (that was completely rebuilt 7k ago)
I checked the coolant and it had lost around quarter of a pint so I topped it up when the engine was cold. I checked it the next day again after a short run and the coolant level had dropped again. I squeezed the top hose once and the coolant level went back up to the exact correct level.
The next morning I went to the airport at 4am and with the climate unit set to 22 degrees it blew cold. I incresed it up to 32 to get a bit of warmth in the car and it blows hot. Ive discovered at 31 degrees it will only blow cold and at 32 degrees it blows hot.
The coolant level appears fine when cold and my local garage say they cant find any airlocks in the cooling system.
Can anyone shed any light on this?
