Hello! Quick question. Can I put m52b20 1998 e39 engine to my 1997 e39 what had m52b20 1997 engine? I have some kind of siemes ecu.
Super Moderator
If they are both pre 9/98 with single vanos they are the same with MS41 ECU. Post 9/98 is with double vanos and MS42 ECU, not compatible.
Vendor
You would be better of using a 2.5i or much better a 2.8i
BW chiptune
Tuning BMWs since 1991
Dyno Dynamics rolling road.
BW autorepairs
Over 30 year repairing BMWs.
New and fully refurbished BMW/Alpina ,Ecus (DME,DDE)and Cas units.
BMW Ecu repairs.
Key data fixed for non starters or when theft attempted.
UK
0208 561 1818
07831 103030
Hayes
UB3 1BB
or
Spain
Orihuela Costa
+447831103030
Discussion Starter · #6 ·
ok, ofcourse 2.5 or 2.8 is better but then I have to change ecu or re program it. And is harder to point out problems if I get them. I putted m52b20 and it worked nice. There was no problem on change. Egine I changed is overheating so I have to still figure it out.
Thanks for the responses!
