Any help appreciated, the old girl turns over but not even a cough!
Battery fully charged and plenty of power to starter, have tried various things:
Put a couple of gallons of petrol in in case the tank cross pipes have come adrift
Checked diagnostics on laptop (carsoft package) no faults
Checked internal diagnostics, coming up with fault 6F4828, can't find reference to this anywhere
Changed fuel pump relay and checked fuse which has 12v
Pulled out hair and hit the bottle
Any ideas anyone? :
Try disconnecting the MAF sensor and trying again.
If that works then you probably have an air leak, if like mine then the air pipe between the MAF and throttle body.
If there is nothing at all then check the sparks are sparking or measure voltage of one of the HT leads. If you have air and you have spark then there is only one culprit left.
Fuel filter clogged would cause issues but i'm not sure it would cause a total none start. There is allsorts of threads about fuel line tests if everthing else seems good.
