Hi,
I own a 318ti 1995 (E36 M42) and I can't accelerate when the engine doesn't reach is normal operation temperature. It mean when the weather is low (0 to 15 celcius), the engine cut off/jerk at 2-3000 rpm. The cut off progressively desappears. When the weather is high (20 to 30 celcius), the jerk/cut off engine is notificable at 4-5000 rpm until normal operation temperature.
Otherwise, the car run very good. I live in Canada, I can't imagine what this problem look during winter.
What I check/replace
-Spark plug ok/spark plug cable are new
-Idle is good, ICV cleaned
-Engine temp. sensor new
-Do not seem have vaccum leak (brake cleaner test ok)
-resoldering DME
-No CEL on
-code 1286 stored in DME, but I don't think there a link between my problem
Any idea?
You could disconnect the oxygen sensor and see if it improves.
You could also disconnect the air flow meter and see if it improves (M42 still has mechanical flap I think, but I think the DME can run in limb-mode without it, not 100% sure though)
You're sure you changed the ECU/DME engine temp sensor, and not the instrument panel engine temp sensor (not sure if it's a combined sensor in the M42)?
Did you check the DISA valve?
It would be good to drive the car to someone who can read the live-values (INPA software for example), with the engine running.. You'd probably spot what's the problem.
Good luck! Cheers Ed
