Hello, can anyone remember or know if BMW did a recall on the M3 evolution for the vanos??:confused
Been looking for an Evo for a few weeks now. seen a few noisy units!:madI don't think there were any recalls on the vanos at all mate.
The bolts that secure the solenoid covers had a habbit of shearing off and causing major engine F-ups..........now, I'm not sure if these were changed as a recall or whether BMW started chaging them when the M3's rolled in for a service.
Why mate, you got issues with a Vanos?
Going to look at a car tomorrow, exchanged a few emails with seller, he says that it has had the vanos recall?:shifty:
SMG:thumbsdownIf you are buying an SMG, then the vanos will be the least of your worries dude.
often the clutch slave cylinder, and sometimes the master cylinder will need replacement as well, but are not expensive, I got mine from bmaparts.comOne tip that almost caught me out when checking out evos. Even if you don't drive the car on the test drive, ask if you can move the car on the drive etc to check the clutch biting point. Most bite on the floor and it can be difficult to engage gears when hot. Don't accept the response that they all do it!
Good haggling point and can usually be solved with a braided clutch hose and bleed.
