I have a an E36 320i 1995.
The front passenger seat when someone is sitting in it is making load clunking noise every time I drive over a bump or around a corner and its driving me mad.
What could be causing this and is there a way to stop it?
Just doubled checked and all the bolts are tight to the floor. Its hard to put enough pressure on the seat and look underneath at the same time.
I can't see anything loose any where. The noise is not coming from the floor rails it sounds like its coming from up under the seat itself some where.
use the middle lever i think to lower the seat as low as possible. i had the same problem and that sorted it for me.
