Good point.I was looking into this w little while back... When I took the door panels off it looked like the rod which goes into the door fills the whole pin. I.e. if you put a shorter pin on it it is more likely to just leave a gap around the bottom.
Little pic to illustrate what I mean. However if you find out that this isn't the case let me know as I'll be doing it ASAP!!
