hi there. trying to source a back cushion because mine is a bit ripped up with wear. do the e36 coupe back cushions fit the saloon?
(the bit that the rear passengers sit on).
thanks.
Unfortunately not, if you examine pics on google images or even realoem.com and check part numbers, the rear seat in the coupe is slightly different.
Saloon Rear Bench = 52208151950 - http://www.realoem.com/bmw/showparts.do?model=CA12&mospid=47434&btnr=52_2172&hg=52&fg=30
Coupe Rear Bench = 52208130116 - http://www.realoem.com/bmw/showparts.do?model=BE11&mospid=47424&btnr=52_2178&hg=52&fg=30
You might be able to make it fit, but I would be inclined to think that if this was possible, why would BMW have bothered to make two different rear benchs for the two models (if one would do for both)?
Hopefully someone with more experience with fitting interiors will be able to helpy you out! Good luck with it either way!
Reactions: xpress
