hi
had my car for around 6 months now and decided to try and fix the dash clocks as the milage display only showed the top half of the digits , and kept going on and off , so i checked out the conections at the back and all were intact , the car came with a spare set of clocks that the previous owner was going to fit , so i ve fitted these , you can now read the milage ok(although a lot higher) but it s very dim (like a bulb has gone ) the old clocks half display was bright , so is it a bulb or the lcd display thats at fault ?? and is it better to get the original repaired or just get another set ?
cheers ant:thumbsup
cheers ant:thumbsup
