1 - 9 of 9 Posts
Hi,
Just done a coolant change. Bit fiddly but got there in the end !!
Can't find any info on bleeding afterwards.
Is there a bleed valve anywhere on the engine/system ??
Hi,
Have you looked on the radiator itself?
No bleeding needed. There are no bleed screws.
drain and fill coolant with fan switched on, heat on full.
fill to max on expansion tank, fire the car up, let run to temp, let thermostat kick in.
Switch off, let cool down......top up if needed.
The E36 M3's are simple as that unlike other beemers that can be a nightmare.
1 - 9 of 9 Posts
