Hello all being a bit thick e36 323i manual revs clean when sat or with clutch in but driving its fluffing and holding back just checked the pipe to the maf and thats ok cant be plugs runns to well on tick over ideas please peeps maf coil packs ??????????? thanks in advance
Guesswork without proper diagnostics, but things like MAF and dodgy cam sensors can cause these issues. Try disconnecting the MAF and driving it. If it's better then thats a nod in the right direction. Does it start quickly when hot? If not check the exhaust cam sensor multiplug. Disconnect it from the sensor and check for oil contamination (common issue) in the plug itself, if so clean it out with contact cleaner. Test pins with multimeter while you're there. Centre pin should read 5v or so, the others two - one should be 12v and the other 0v (ground) - check with ignition on. This will rule out a wiring issue on that sensor. Remove sensor and clean with cleaner as it will be all gunked up no doubt. Refit and re-try the car.
