i was under the impression that the 318is's all came with an oe lsd setup in the rear. is this correct or have i been misled somewhere along the line.
any help is appreciated.
cheers.
pauly
can you do a donut?
yes = car has lsd
no = car has no lsd
IIRC, all E36 Sport model's came with a LSD :)
yes but ive done plenty of donuts in non lsd cars!!!
if all sport models came with lsd's does this include all 318is's then?
cheers.
pauly
LSDs were a optional extra in the 318is IIRC.
And if you have a e36 with traction control then you won't have a LSD as standard, on the diff casing you should have a S printed/painted on it if you have a LSD, also on a tag there will be a S
aaah, that would explain alot then!!! i will check the tag/ casing tmrw! thanks for the info!
deff no traction control button.
thanks again.
pauly
On the 318is it was an expensive optional extra. Rarely taken. I believed my old one was but i did home work. 318 is an option.
Stick a wheel in thick mud and one on tarmac and wheelspin. If the wheel in mud spins but other not so much then you dont have lsd. lsd would force the other wheel to spin also. (probably pulling you out mud)
