Nice one. but how did you bypassed the EWS?i have a m50 325 engine fitted to my 318is did the m50 engine suffer with nikasil problems
is it cranking?Nice one. but how did you bypassed the EWS?
mine BMW E36 had M52. Was fitted in M50, but it not starting
any ideas?
thanks
Yes mate. It's cranking. No petrol, no spark :frown :confusedis it cranking?
have you cut pinYes mate. It's cranking. No petrol, no spark :frown :confused
fuel pressure regulator??(just a guess) if its sparking and fueling there's not much wrong! did you hear the engine run before you put it in?the harness was just the one that wires up the engine with the service socket on it with the relays etc but not the fuse box.....
the ecu is a bosch 0 261 200 413
the car its gone into does have the chip in the key but the car does turn over and the injectors fire + all the other electrics work fine
just been out at it again, i have changed a few of the hoses for new and have re checked some things and the plugs do fire!
but......
still no joy
it seems as thair is too much fuel geting through as i took the fuel pump fuse out and it did fire a few times but not enough to run properley,
not sure what to do now as the relay is fine...
any ideas?
cheers
Andy
