Hey guys im after some more help.
This morning when i finished work i turned on the ignition and my Rev and fuel tacho's went from left to right and interior lights started flashing but engine wouldnt turn over. I left it a min then tried again. Same thing happened but then all lights on dash stayed on. their was still life in the battery but wouldnt start. My mate gave me a push and i bumped her then she started. I didnt want to stop so came straight home.
I had a look under the bonnet when i got home and engine still running but couldnt see anything out of the ordinary?
All i can think of is maybe the battery is on its way out because it looks old.
Any clues??
Thanks guys.
more than likely, its been cold recently and it just drains loads of life outa a battery if its old, i had the same problem theyre not too expensice think i paid fbout 40 for mine.
i might treat the car to a new battery anyway but i just went out to check the car again and it started first time with no trouble. So now im not too sure if it is a battery problem.
No sign of leaks and engine sounds normal. Maybe some crap fuel or filter need changing???
