1 - 16 of 16 Posts
So its been in the garage for a few days, and the temp has stayed bang in the middle. He said he cannot find any external leaks, but that the system was getting "a bit pressurised", but not too bad. He also said there was no air blocks etc.
Any ideas?
(The symptoms were: Went to 3/4 on the gague until I revved it and then went back down, and blew cold air, but again, when revved it was fine and hot air was blown????)
BFuk Legend
Im not sure either now. You will always get a bit of pressure, but the hoses shouldnt be rock hard to the touch.
Also, i know it may sound silly but the radiator caps used to cause problems on these. I have a recall notice in some of my paperwork for my car. It is also quite common to screw the caps on pissed. I know coz ive done it myself :embarrassed
I just called him about the rad cap, he knew about that problem so its not that.
The hoses are not rock hard, but a "bit hard" lol. He suggests just using it and see how we go on, but there MUST be a reason somewhere.
Still, I am away till Friday now so he has a few days to keep on at it.
Thanks for your replies.
BFuk Legend
I would prob get the head gasket done if it were mine. Prob cost the same sort of labour. I would get a sniff test done first to double check if the headgasket has gone. Ill search for a post about a sniff test kit. :)
Discussion Starter · #14 ·
The garage called me today-full 3 day investigation, they have used it to collect parts etc (to test usual temps and use) but its not used any water or overheated!
So I have no idea now-i dont know if I should get a test kit or not.
I would also ensure the cooling system is bled correctly, not trying to take the pee but I've met experienced mechanics who can't bleed cooling systems.
Otherwise a sniff test/block test is a good idea.
1 - 16 of 16 Posts
