1 - 9 of 9 Posts
Super Platinum BFuk Member
Non Sport springs front are 401mm & rear are ;)341mmm
Crazy,mad.. I am probably being a plonka but something is wrong. I don't have a standard front spring but both Eibach and PI
springs measure around 270, the 2 different old springs that came of the rear were different lengths, so the shorter one measured
around 310 so they must be m tech rear springs , but the fronts at 270 would be 130 less than 400, am I measuring correctly.
That's 5 inch drop.
pass.... but i will say your old springs will have sagged so wouldn't necessarily be the same as when they were new.
That's 5 inch drop.
Are you quite sure your tape hasn't got a chunk missing off the end:silly
just replace front springs on my bmw e31 850ci the old springs were 270mm to 290mm long and the replacement eibach springs were 260mm to 280mm dependent on which side you measure them
1 - 9 of 9 Posts
