DME EWS Alignment issue
10K views 11 replies 7 participants last post by  Clavurion
#1 ·
Sorry for another thread, been raking though the forum to try and find info that could help me but as a last resort here is a little cry for help!
INFO:
have just done and engine swap in a 96 316i, have instaled a 95 m52 2.8
DME = From 328i
EWS/keys/ rest of the loom mostly untouched from the 316i
Bought a data head from ebay to help me with this, Im able to read info from both DME and EWS, also able to clear error codes turn on fuel pump and things like that. SO i believe that i am "pluged in" Have used the EWS-DME alignment part of the package but st still docent start, throws a ews incorrect password error on the DME error memory. I have also tried setting the ISN number manually: reading it from the DME coding screen and writing it to the EWS, still no luck.
Information prinouts:
EWS info
DME info
DME coding screen :
And finally the EWS error :
I have kind of hit a brick wall, im not sure if im doing somehting wrong, the ews and dme are not comptable or perhaps the DME is faulty?
I know the EWS and the rest of the car loom is fine as i had a running. the DME and the engine loom are another matter, not seen the engine running...
And help would be great!
#5 ·
Thanks for the advise. Had a look at there weere several ews/dme align options tried them all still no luck.
Thinking back i may have damaged the EWS... when stripping the car i hooked up a battery charger to power the car when the engine was out. i had a little accident... charger was on 24v..
Saw a dme/ews/key package from a 328i coupe on ebay.. hopefuly this will save a bit of agro.
#7 ·
SOLVED:
OK To clear up what i had:
DME - 328i
Engine loom - 328i
Car loon - 316i
Ews/key - 316i
I went and bought a matched DME, EWS, key, transponder & antena from ebay
After alot of testing i found out that the DME that i origionaly bought was a DUD
SO now have (running car):
Engine loom - 328i
Car loom - 316i
DME/EWS/Key - 328sport
Now i have spare(tested and working with new DME after aligned) EWS/Key/transponder/antena
