1 - 20 of 24 Posts
So I've put a 184 330d lump in my 320d compact e46 but the wiring for the ecu from the car loom is different. The engine is all conceded to the ecu it's just the body side that's different.
Please can somebody help
Discussion Starter · #6 ·
This is the main bit I need. This is the plug removed from the m57 body loom. If I can match this to what's coming through the bulkhead on the compact I'll be good to go
Wire Cable Electrical wiring Electronics accessory Technology
Picture of the 40 pin connector from m57 body loom
Electronics Technology Electronic device Data storage device Computer hardware
Picture of location on ecu
Hope this makes sense
Discussion Starter · #10 ·
Lol no I didn't relies they were links but that's the same info staggered across. Going to sit down over the weekend and try and rewire the plugs.
Thanks for your help dude, I'll let you know how I get on
Hi!
Could you please share where you found the pinout for bosch dde5? I am in the process of swapping m47tud20 to m54b30 and need to find the pinout to connect the m54 engine harness to the body.
Really appreciate the help. :)
1 - 20 of 24 Posts
