Has anyone experienced loss of signal on a DAB station. I get a message on the screen that says NO Signal. Once that happens DAB doesn't work at all. FM works perfectly well.
I rarely use DAB, go behind a hill and as it's digital, and coverage is still a bit hit and miss, unless you get 100% signal it cuts, normal radio copes well with partial loss of signal from time to time.
I would though, expect once get back into a good DAB area, that it'd work again!
There are coverage maps on one of the DAB sites...
Thanks for the explanation, however this has just started after 18 months of perfect reception
This just started on mine, its the heated rear window at fault for me, common issue so it seems.
