can anyone tell me where the crank sensor is located on the b47 engine and how difficult is it to change ?
passenger side at rear of engine just above the sump, 4mm Allen key holds it in. Can just about be done from up top but so much easier from underneath.
If you shine a torch down below high pressure pump you will see the plug on it,the sensor itself is recessed in.
What do I need to remove to get To it ?
