Hi hope someone can help my 520 GT the offside gutter trims and door trims are marked i had the near side ones changed under warranty before my car was 3 years old , but know speaking from experience the Stealers will won't to charge a fortune to replace them but I would like a bit more of a permanent job as the newer ones are not looking that good.
I have seen somewhere you can have the strips taken off and covered with black film and it looked very good!
Hope someone can help.
hi, I know that you can buy plastidip, it's an aerosol can and it sprays on like paint. The more layers you spray on the more thicker it gets, maybe you could try that? If you don't like the end result then you can peel it off.
You can do this yourself as you mask the windows and half of the window screen each side.. then it's easy to do.
I think you can buy chrome/metal cleaner/polish to sort this. Will just take a small layer of and look good as new.
