Any ideas how to change/ replace the squirter nozzle unit that's on the underside of the bonnet passenger side... I put a pin in the hole to redirect the direction but must have enlarged the eye hole as the water doesn't spray into a neat stream it just floods out and doesn't hit the windscreen
May possibly be dirt in there interfearing with the spary jet. Use a piece of wire out of a wire brush or something similar and run it in and out a few times. Might solve your problem
Thank you for the reply, Just to clarify the jet is not blocked its the opposite of blocked I have enlarged the outlet hole by trying to clear it and now the water floods out rather than squirts out.. has anyone ever changed the whole nozzle block? if so please can you tell me how to change the entire unit
