Hi,
i have a E93 2010, i have 2009 maps and want to update them is that possible? My current version is below. I take it i cant be the first to update it and wondered where you guys got to get the updated maps? BMW branch basically said we can look into it for you with a wink, meaning it costs a fortune, so presume people are getting these outside OEM disk updates? Hope its ok to ask as i am getting sent to lots of crappy sites which dont have the cd/dvd updates.
ECE
BMW
1.5.20
Road Map Europe PREMIUM 2009-2
Discussion Starter #2
I have found a site with E93 stated on it with:-
The Road Map Europe PREMIUM 2019-1
But its going on about USB stick, my car only has CD/DVD. So can i assume they send it as a DVD or do i need to copy the USB files to CD or DVD for it to load via?
https://navupdates.co.uk/downloads/road-map-europe-premium-2019-1-fsc-code/
Updating your maps through the Glovebox USB port is the fastest way of performing the update. The procedure is simple and is detailed step by step in the instructions file you will receive with your map and code.
Compatible vehicles:
BMW E60, E61 from 11/2008 to 05/2010
BMW E63, E64 from 11/2008 to 07/2010
BMW E70 from 10/2009 to 06/2013
BMW E71 from 05/2008 to 07/2014
BMW E81, E82, E87, E88 from 09/2008 to 03/2014
BMW E84 from 10/2009
BMW E89 from 04/2009
BMW E90, E91, E92, E93 from 09/2008 to 10/2013
BMW F04 from 11/2008 to 06/2012
BMW F06 from 03/2012 to 03/2013
BMW F07 from 10/2009 to 07/2012
BMW F01, F02, F03 from 11/2008 to 07/2012
BMW F10, F11 from 03/2010 to 09/2012
BMW F12, F13 from 12/2010 to 03/2013
BMW F20, F21 from 09/2011 to 03/2013
BMW F25 from 11/2010 to 04/2013
BMW F30 from 02/2012 to 11/2012
Ok boo hoo
Seems Bimmer.net states 2019 BMW Navigation Updates - Activation code included.
Cars made before 03/2010 with original firmware (no update since you bought the car), then you can ONLY update to 2014 map via DVDs.
We strongly recommend customers with cars made before 03/2010 to have your car firmware updated from local dealers in order to update to 2019-1 and future maps by USB memory stick.
So it seems i need to go to BMW after and and update in order as i have the original SATNAV 2009 s/w and car was not registered until 04/2010 so obviously manufactured before the cutoff date above.
Well at least i tried. WIll go check later what the damage will be to do this at local BMW dealer.
