cam removal
1 reading
4.3K views 15 replies 3 participants last post by  Boostist
#1 ·
is it possible to remove the heads with the cams in place? if not can you remove them without the special tool?
#3 ·
You may well have to remove the cams to get the heads off mate. it depends if you can unbolt the head studs with the cams in place.
I know with ARP studs it is possible to do it but not tried it as a whole TBO
They can be removed without the special tool but the cam caps MUST be kept meticulously in order (numbered or whatever) with their own cam journal.
I cant remember if the journals are numbered but if not number as you remove .
On a 325i I had to drop down the oil pan, rand remove the vanos unit and timing chain to help a friend do his head gasket. But we had the Cam removal and alignment tools and he installed Schrick cams at the same time.
Does anyone know a BMW special tool hire source in the yUK?
its a major PITA not being able to get some of the tools as they are so expensive for single use jobs :confused:
This is a very good article on removing them even tho its the US engine
Cam removal
#7 ·
official word from my mate at bmw is that their mechanics dont uses this special tool and have never had one in his dealership they just unbolt them very slowly. i didnt look for the sweet spot thats described in the write ups but just undid the intake cam 1/4 turn at a time its still in tacked as far as i can see
#13 ·
oh yeh mate i know its only surface when i feel little better ill strip the lot out (crank etc) clean the crud off the block/head and ill rub some fresh oil over the bores etc before wrapping it up for machining
