Afternoon guys,
Apologies if this is a long post, just keen to give all the details.
So I took my car in to have the water pump changes and had the brakes done while it was in there. Since the car has come back, it doesn't seem quite right. It almost feels as if the brakes are permanently slightly on. For example, my drive is on a slight downward slope. If I give it a very slight acceleration to get it going and dip the clutch, the car comes to a stop whereas before if would continue to roll (as you'd expect). The garage puts this down to "cold weather" but it's been mostly above 5°C so it's not particularly cold anyway.
Then today I was driving on the motorway and the below symbol flicked on and off quickly every now and then, which didn't do much harm. Then it started flickering continuously whenever I applied any acceleration. This was at about 60mph, and while the light was flickering I could only maintain or reduce the speed. I stopped for 10 minutes, set off any no further real problems. On the way back it did a similar thing where it wouldn't let me accelerate but not to the same extent as I was going a bit easier on it.
Has the garage doing the brakes caused a problem with the ABS? Or installed them in a way that's too tight which is causing the resistance as well as making the sensors go mental?
Obviously I've booked it back in for them to look at it but would be good to have some ideas from other sources.
Thanks for any help you can give
