I just changed my rear brake pads at the weekend, tried to reset the dash warning light but it just zero'd the rear (and front) service intervals to '-------'. I didn't replace the sensor, could this be the problem?
The reset procedure i tried was to press and hold the trip button (on the dials), scroll through the menu with the toggle (on the left stalk), then press and hold the BC button and then again press and hold the BC button. It says 'resetting' but then goes to zero. Is there a way to manually input and what mileage would you input?
I can understand maybe the old sensor would cause the problem for the rears but i didn't even touch the front brakes. Any suggestions?
116d E87 2011
116d E87 2011
