1 - 1 of 1 Posts
Hi all I just need some advice on using my old crank and pistons in my second engine as I've found that 5 rod bearings have been rotating and knackered the crank and rods my problem is when I disassembled my first engine I never kept the pistons in order and I'm having trouble finding what order they go in I no it's got something to do with the letters and numbers on the crank it says 2222222 bbbrrb
My plan is to re-use this crank as it's spotless and the pistons with new std size bearings and piston rings checking the clearances of everything
Engine is n53b30a
Any info would be great cheers
1 - 1 of 1 Posts
