1 - 1 of 1 Posts
Hi everyone, I have a problem with the turbo boost. Basically when I push the gas pedal the car does not respond as normal. It hit the revs but doesn't pull.
I installed an egr delete kit, removed the egr cooler, replaced all glow plugs, manifold gaskets and swirl flaps deleted, egr vacuum nulled and radiator pipes blocked.also replaced the throttle body dpf nulled. checked the intake pipes and turbo pipe and is not cracked.
Scanned with insta and got the code 00483D DDE throttle actuator, but perform a test and it works fine.
What else can I check?
1 - 1 of 1 Posts
