1 - 1 of 1 Posts
So got a e46 clocking 150k miles, and have the eml on. I've used a ODB reader to check the code readout and can only find the P3263. I've looked through the forum and so far everything I've seen is related to swirly flaps, however I don't have any (I think) When I brought the car alot of work (with receipts) had been done including, new turbo, new clutch and flywheel, recon gearbox, aswell as an engine rebuild, including timing chains, valves and rocker arms, and allegedly the swirlflaps removed, although this part itself isn't listed on the receipt. So I've got a couple questions; 1) is there any easy way to check for swirl flaps existence?? 2) could it be anything else!?? I'm gonna clean the egr and MAF tommorrow as I'm unsure when this was last done anyway, also the car has been remaped and decat, and has no problems running.
1 - 1 of 1 Posts
