Hi All,
i need some help with a couple of issues i'm having on my F06 640d.
Over the past couple of years I've had an issue where when i turn the car on and drive off, there is no power whatsoever, almost as if the turbos aren't engaging. however, the reason its been 2 years is that I've found a work around.
What i do is turn the car on for 10 seconds, then turn the car off completely for a few seconds then turn it back on and this seems to sort the problem out.
when i had it checked, the error code that as coming up was 2C3200 - Swirl flaps, plausibility: mechanically fault (lever break detection).
On realising this, when i do the first turn-on of the car and rev the engine, you can just about see the green actuator arm and it isn't moving, however, when i turn the car off then turn it back on as per the above, you can then see the actuator moving when revving.
I then thought it'd be a good idea to get to the inlet manifold and give it a clean due to the EGR valve and the carbon build up.
i wanted to ask if anyone has come across this problem before and why does it work when i turn the car on and off? could it be something to do with the battery not giving the actuator full power?
i managed to find a spare swirl flap actuator motor on ebay to replace it but thought i'd ask if anyone has had this problem before and could this be another problem which saves me from having to replace something that isn't actually broke.
