Hi! Since i buy the car, i have a problem with can modules, but today the car went to limp mode, so i want to figure it out what's wrong.
CAR: 2003 BMW e60 530i - M54B30
My error codes after limp mode:
28DD - DME: Air mass system - Existent
28AE - DME: Torque limitation: Monitoring - Existent
5F77 - DSC: Engine management: Interface - Existent
D904 - CAS: K-CAN line fault - Existent
D907 - CAS: K-CAN communication fault - Not Existent
E584 - KBM: K-CAN line fault - Existent
E587 - KBM: K-CAN communication fault - Not Existent
9C77 - IHKA: Auxiliary-water pump - Existent
E244 - SZM: K-CAN line fault - Existent
E2C4 - CON: K-CAN line fault - Existent
9E5C - SMFA: Rapid heating area: cushion - Not Existent
E444 - SMFA: K-CAN line fault - Not Existent
E484 - SMBF: K-CAN line fault - Not Existent
E184 - CD/ M-ASK/CCC/RAD2/CHAMP-GW: K-CAN line fault - Not Existent
FFF2 - MOSTSYS: MOST ring break - Unknown
Codes after deleting:
E504 - LM: K-CAN line fault - Existent
I already tried:
I already tried:
- Cleaning ICV, Throttle Body. Re do and cleaning plug connections. Adapt Throttle Body.
- Replaced SGM, LM to LM2, DME, CAS
- Redo plugs in SMFA,SMBF, SZM, M-ASK
- Replaced MPM
- I tried to disconnect SMFA,SMBF and check, but nothing changed.
