hi i've got an issue when braking at low speeds the car will make a loud juddering noise and the brake pedal will go stiff and judder then stop after a few seconds i have a feeling it could be the ABS pump can anyone confirm this or any other thoughts are welcome also not sure if its linked but the ASC light and the ABS light on the dash don't work. any thoughts are greatly received.
thanks in advance
i bought the car in may from a lad at work he said hes never had that problem with it but i think a diagnostic check is the best bet. cheers for the quick response
i had the same problem, previous owner had removed the bulbs and i didnt notice when buying the car (it wont happen again). haha, but the same ABS kicking in at low speeds and having this problem wont trigger the warning lights anyway because as far as the system knows its working.
took it to my garage and matey told me it was the ABS pump. (£850) from bmw.
got a refurbed one for like £200. plus £100 to fit.
Also, Be warned that it seriously affected my braking ability and after nearly rear ending several cars I removed the ABS relay until I got it fixed.
