1 - 8 of 8 Posts
Hey guys,
After predominantly owning VAG cars, I finally bought an E90 325i M Sport. I bought her a little on the cheap side as the “ABS light” was on. New to BMWs I had no software or way of fully diagnosing the problem at the time of sale, so I took a risk and thought it can’t be that bad to fix.
After some research online I quickly realised that BMW diagnostic/coding software is not as user friendly as VAGCOM. However I managed to purchase a package of BMW software (including cable) on eBay for about £55. This Included:
• INPA Ediabas
• ISTA (BMW Workshop diagnostics)
• SSS/Progman
• TIS
• NavCoder
• NCS Expert
• WinKFP
After finally plugging the car in, I had an array of DSC unit errors. Ranging from pump pressures, VIN numbers not matching etc.
By coincidence a few days later I had to move the sister in laws 118D. When starting her car up, I noticed her dash had a lot more lights than mine. This got me thinking, why isn’t my dash the same.
Long story short, after undertaking the instrument cluster light test, I noticed 2 bulbs were ‘broke’. On opening the dash, this is what I found:
The previous owner taped over the handbrake and traction control lights! This was to try and hide the real issue on the car, and to play it off as an abs sensor or more minor fault.
So after more research, the 3 lights of death pretty much indicated to me I needed a new pump or to get mine repaired. No problem right? After more research, I discovered the pump fitted to the car was the wrong one! My car needed ABS Pump 6777162, where I had a different number fitted …………
So I decided to try and source the correct pump and fit it. For 2 months I rang up scrap yards and breakers constantly, no one could get me one. This pump is rare! I then decided to ring BMW to see what the damage would be for a new pump, they quoted me £1700 ex vat. I asked them could I get another pump to work, which they responded no. They told me the ECUs would not be compatible (take note here …..BMW ‘plug and play’ mechanics aren’t always correct).
I was adamant that another pump could work on the car. As long as the pump ECU could speak to the ECU on the car and was designed for the weight and brakes fitted. BMW have 2 main style of ABS pumps, 4 cylinder and 6 cylinder pumps. My thinking was that if I get a similar 6 cylinder BMW E90 around the same age, there is a good chance the manufactured ECUs would speak and hence would work.
So I purchased a pump off a (same age) 335D – Part number 6777159. After initially plugging this into my car, there were no DSC Faults! However whilst stationary, the speedo would fluctuate between 0-15mph and whilst driving the car would brake if i tried to drive over 20mph! I decided that pump was not suitable for the car!
I then purchased a pump off a 2 year older 323i – Part Number 6775388. This pump was successfully installed and programmed to my car! So yes BMW it can be done! However getting to this stage was a bit of a headache. Hence the reason I have written this post.
Now I won’t go through fitting the ABS pump, as that is fairly simple: Disconnect the brake lines, bolts and unplug it. Reinstall new pump and bleed the system. The coding of the pump is what I struggled with.
After installing the new pump, I had the following error codes:
• Error Code 005DD2 - DSC: Hydraulic unit: adjustment, DSC unit (valves)
• Error Code 005DD0 - DSC: Hydraulic unit: adjustment, DSC unit (valves)
• Error Code 005E50 - DSC: Steering-angle sensor: serial number; calibration required
• Error Code 005E1F - DSC: Control unit: incorrect vehicle identification number; calibration required
After my research every forum says use SSS Progman or NCS Expert. So I decided to use NCS Expert first of all as it is most simple to use.
When you have NCS Expert loaded with your car plugged in and ignition on. Select “File > Load profile > ExpertMode > OK. Then select your chassis by selecting F1, then selecting F3.
It then asks which computer we want to code. Select one of the available options like CAS or EWS or LCM. You then have to select “F6” to go back. This will then allow you which ECU you want to code.
So for this case, we want the DSC module. So select F4 and select it. Then select F2 job select, and make sure the job name is on SG_CODIEREN and press okay.
Then select F3 to process the car. This in theory is how the new ECU is coded to the car. I however had no luck with this method.
I then decided to use SSS Progman. This is a very simple piece of software which again pretty much does the coding for you.
When you load the software, select New Session. Then click your interface and continue. Then select your car and model. Once loaded, click on ‘Load SW’. It will then ask you if you have replaced modules, select yes for the new pump. The software will then list all the modules on your vehicle. Select DSC to code it. After clicking continue, the software will create a measure plan and try to process the recoding.
However at this stage, my car failed as the software told me I had the wrong pump for the car and told me to replace the unit! SSS Progman will only work if you have the exact pump the car should have!
After more research I discovered I could code my cars VIN number into the DSC pump by using some software called Tool32.
Once you have plugged your car in and turned your ignition on, press F3 and choose your ABS module. For me this was 'dsc_87.prg'. This will then load a series of jobs. To code your VIN number into the ABS pump, look for the options called 'c_fg_schreiben' and 'c_fg_auftrag' in the left column.
Once you find them, select 'c_fg_schreiben' and at ‘Argument’ type your car 17characters VIN and at the end put 1. So for example if your VIN is WBAVA71030VA22222 you will put 1 at the end and that should look like WBAVA71030VA222221
Once you have typed it, press F5 and it's done. You should then select 'c_fg_auftrag' (If you have it) and press F5.
This however did not work for me! After further research, I then discovered you have to calibrate your steering angle first to code in your VIN number. This can also be done in Tool 32, so repeating the above processes in Tool32, then select "lenkwinkel dsc abgleichen" (to select steering angle calibration) in the left column. Make sure your steering wheel is straight and type in your VIN into the arguments section again. Press F5 and your steering angle calibration, and VIN programming should be complete.
Using Tool 32 should clear the following codes:
I was then left with the Hydraulic unit: adjustment, DSC unit (valves) fault codes!
After more research, and with a bit of luck, I discovered a DSC pump calibration in ISTA.
When you load ISTA, select your vehicle and undertake a ‘Vehicle Test’. After the diagnostic test is complete, your fault codes should display. In the bottom right corner of the faults page, there will be a button saying ‘Calculate Test Plan’.
When you click on this process, ISTA will work out the necessary actions to rectify the faults in your vehicle. So for the DSC valve adjustment, the software will recommend a pump calibration process (this can be undertaken in ISTA).
Select continue with the pump calibration process. However at this stage, make sure the system is correctly bleed and installed. The software will then run the calibration process (this takes a few minutes). Assuming your pump is in working order, this should calibrate your pump and clear your fault codes.
So after 3 months of owning the car and installing a few pumps, the ABS issue was solved! I was very happy to see the picture below …. No faults!
Hopefully this will help some of you save some money off BMW dealers and enable you to install and recode used pumps/ECUs to your BMWs.
sounds like you had a nightmare from the start paying £50 for ipna which can be dowloaded free all u need to buy is a obd cable to fit or make one. I had mine replaced on my 330ci years ago. Sourced the part form breakers £50 installed,bled and vin number updated to match the cars ecu all done by my garage within 60 mins.
I think they used autologic software at garage to update the vin but it didnt take long at all. A year or so after i read another post someone managed to get around coding by unplugging the battery first before taking the abs pump out so no coding was needed once new abs pump fiited and battery plugged back in
good write up though hope its all sorted now
read my post again mate you dont need to code the new abs pump if you disconnect battery first as the ecu will see no errors....lol
Hi,
I am about to do the same on my car..
When you calibrated the DSC in the end, you used ISTA-D, or would you need ISTA-P as well?
Thanks!
Dsc recoding
Hi is there anyone out there that can help me. I have a Bmw 1 series 2008 i have just changed my DSC module as the last one was faulty. I have got rid of most of the faults. But it has left 4 faults which are:
5E50
5E3F
5E1F
5E2O
I believe these are due to the vin not matching with the new unit and pressure sensor. Does anyone know where I can get my DSC re-coded or is there anyone out there who can do it for me I don't mind paying. It's just starting to get me down, I am in the Birmingham area B34 thank you.
Regards
Mark Kirwan
5E50
5E3F
5E1F
5E2O
Regards
Mark Kirwan
Did you ever sort this out?
1 - 8 of 8 Posts
