Hi all.
I've just changed from my old E39 530d to a 2015 F11 530d Touring. A month into ownership, the rear suspension is misbehaving on the F11 like so many others.
My 2015 F11 has done about 50k miles.
It's got an Arnott air spring on the left, OEM on the right.
I just bought an Arnott air spring for the right, I figure it's only a matter of time before it needs replacing even if it's ok a the moment (I think it is, no sounds of air leaking).
Suspension deflated a few days ago - my wife was driving, she wasn't watching for when it deflated.
I drove the car after it had been parked for a few hours and the air suspension re-inflated to normal height.
It stayed up for 4 days until I drove it.
I got out to get something out of the boot then noticed it had deflated completely down to the bump stops again.
I can hear the compressor running for periods then it stops, suspension doesn't inflate, car remains on the bump stops.
So I strongly suspect compressor discharge valve.
A few questions on this:
1) Does anyone know where to source a genuine Wabco replacement discharge solenoid valve? Or a known high quality replacement? Always a bit wary of cheap ones on ebay.
2) I also found that 4x4airseals sell an air compressor piston seal & air dryer filtration repair seal kit for it BMW 5 7 Series F01 F02 F04 F07 GT F11 Air compressor Piston seal & Air Dryer Filtration Repair Kit - 4x4 Air Seals. Has anyone had success using one of these kits?
3) From what I read, one of the problem is the filter and pipe for the incoming air either getting detached or damaged so water gets in. Apparently the air intake is behind the wheel arch liner or bumper? Anyone know about this or know for sure which side that's on before I start taking things apart? Or replaced their filter?
4) I saw in this post, someone made an adapter and pumped up the car manually while it calls for air and the valves are open. Has anyone done this?
Seems rubbish, so many failing either because of air springs, compressors or both at such low mileage. My old E39 didn't do this until an air spring leaked at 120k miles!
Thanks.
Thanks.
