Hi Guys!
I've been working on my 330i and have just upgraded the airfilter and intake boot, alongside adding an M3 Style bumper (decoded the washer jets) then just changed some of the comfort access settings (lights and wing mirrors folding).
It's got full service history with BMW and was recently serviced in May, however, since purchasing an OBD reader and Bimmercode/Bimmerlink I've now got the following error codes:
Safety and information module:
A6CF (AUC SENSOR)
93D0 (Supply voltage - under voltage)
Motor electronics: 30E9 (nitric oxide catalyst, aging)?? 2
E85 (0x2E85 electric coolant pump, communication)
2F11 (0x2F11 radiator shutter, top)
2F9E (0x2F9E Thermal oil level sensor)
Comfort access:
A08C (TAGE_FAT_Antennen_defekt)
A069 (Innenraumantennen_hinten_defekt)
Dynamic stability control (MK60 E5): 5DBD (Pressure sensor rear left hydraulic leakage rear axle)
5DA7 (Hydraulic leakage front axle or rear axle)
5D9D (Front left pressure sensor hydraulic leakage front axle)
5DF4 (Vehicle electrical system voltage <9 volts)
Instrument panel
A559 (KL30g_f shutdown)
If anyone would be able to help me understand these and whether I need to get anything looked at that would be greatly appreciated!
Thank you! 🙌
Roux
A6CF (AUC SENSOR)
Comfort access:
Instrument panel
Thank you! 🙌
Roux
