Hello,
I have a BMW 330D 2006 and recently when i was driving the ABS light come on with the traction control light an the brake symbol light and also a gearcog with a exclamation mark comes on the dash at the same time but it would only come on after about 20/30 minutes of driving (when the car gets hot) and my speedo was dropping to 0 when the ABS light was flashing so i got it plugged in an it come up with a fault saying lost connection to DSC control unit which i believe is attached to the ABS pump, so i ordered a part of ebay which was 170 pound also matching the same numbers as mine so i got the right one (bmw wanted 1075 for a new one) so i got the dsc control unit changed and then all the lights stayed on after i got it changed which i was abit curious about so i took it to a BMW specialist an he plugged it in an it come up ABS hydraulic pump failure so i got the pump changed in the garage (more money an luckily had that one i ordered) and it is doing the same thing even though i have changed that but the faults its coming up with now is Hydraulic unit adjustment (valves), incorrect vehicle identification number calibration required then also says steering angle sensor serial number calibration required also! (Picture below)
sombody must of had this problem before or is my car just shit 馃槀
Thank you 馃憤馃徎
270633
Did they code the replacement module i know you say it had the same part number but still needs coding.
Apparently the bmw specialist did code it he charged me 40 pound, but am not convinced he did because he also told me when i change the abs pump it wont need coding because its already been re coded
