hi
I am bmw 316 on 1999 plate e46 I am having issues with the wipers working intermittent when I use them just by changing speed of wiper the stop working and will not work and if I switch off the car and switch on after a while they will work again until I touch the stock and they go dead.
so fare I thought it may be the stock faulty and replaced it but no difference at all and cleaned the double relay with switch cleaner but no difference I need your help and advice to resolve this problem of mine.
thanking you in advance for your help.
Hi!
I have the same problem.
Have you sorted out the problem?
Hi
I did sort this problem
The connections to the relay socket was the problem as due to vibrations the relay contacts were loose so what I did was pressed the contacts in the socket for relay and that made very good contacts and problem was solved.
It's the base socket of relay which becomes an issue I hope this will help you.
Wbr
Moderator
