1 - 18 of 18 Posts
2019 BMW 530d M Sport
Afternoon all,
I've currently got a 2010 BMW 320d N47 which has quite a loud timing chain rattle at idle, looking to get this replaced in order to prevent a full engine rebuild. I've had various places quote me and have been quoted anywhere form £600 for a full timing chain kit replacement with a two year warranty (great price, I know) up to £1,500 with a 6 month warranty. I'm looking at getting this done reasonably soon, car is currently off the road anyway, but what on average are/have people been paying for these to be done?
Vendor
They got over 30 5 star reviews on google, so that gives some peace of mind.
Never trust google,FB reviews
Make a post on the bmw forums and ask if anyone has used them before
[/QUOTE]
Hi, did you had it done... I know it's an old post but I'm interested if it's worth the hassle.
£600 for timing chain replacement sounds too good to be true to me. I would be asking what make kit is going on it first. I fit named stuff like BGA,fai,hepa etc and you are looking at around £200-250 for parts alone. Then add in various bits and pieces like rocker gasket,injector seals and fluids and it doesn’t leave a great deal left to cover the labour.
I have done a fair few for £400 but that’s doing as a bit of a hobby for friends,if I was a business it would be considerably more to make it worthwhile
bmw specialist which i use charges like £950 for the job,,from his facebook page
If your not already aware of this your 16/18/20/23d Bmw or mini is prone to premature timing chain failure which not included in any routine maintenance plan.
We recommend 60k miles
N47 timing chain replacement
2wd £950 inc
4wd £1150 inc ..
This forum has been great because I've just been quoted £2.2k by a local BMW specialist for this work which I now realise is very very overpriced.
I have a 2014 F30 320d and I now get a slight rattle at cold idle. Its just gone 100,000 miles and has been very well maintained by myself so I'm still unsure if it's worth being this preemptive with the work.
Anyone else with the same mileage/ age and uncertainty?
If there is any timing chain noise you are better off getting it sorted before it fails as it will work out cheaper.
It’s so hard to say about mileage as I have known them to be stretched at 50k and others have gone way over 100k. General consensus is replace chain at 100k. Being a 2014 you could have n47 or b47 as it’s on change over. Having said that if it’s got noise it doesn’t matter what variant is fitted.
Whatever happens don’t pay 2.2k for it to be done.
where are you located?
Isn't it quite a big job that you'd need a workshop for?
FYI, I've had my 2nd quote now which is for £1463. Still a bit more than I'd be expecting. Any idea which part of the quote seems overpriced?
Thanks for your help on this!
Font Number
Thanks for your help on this! View attachment 276839
no not really I have had them out on my drive,done chain work in the garage then stuck engine back in. Working on my own on the drive I can at a push have it done in a day but tend to spread it over 2 days and work at a steady pace. The n47 is fairly straightforward,had an n55 out couple of months back. That was a bit more problematic.
On your quote there is sump and timing case gaskets,you don’t need them as it’s rtv joints. There should also be injector seals as you need to change them. Finally the shaft seal should come in the timing kit,every kit I have had the seal has been with it.
But yes biggest cost is the £763+vat Labour, the ones I have done for friends of friends cost £600 total or £400 for friends unless clutch and DMF needed doing at same time.
x drive models take a bit longer due to front diff and drive shafts.
1 - 18 of 18 Posts
