1 - 1 of 1 Posts
RockAuto offers ATP Automotive automatic transmission rebuild kits. With just one part number, get all the parts you need for your rebuild project. ATP Overhaul, Banner, Master, and Master Plus rebuild kits pre-package all the necessary parts for comprehensive transmission service. ATP kits are engineered to fit and function just like the original parts, ensuring long life and durability.
Designed to be single-source, efficient repair solutions for restoring the performance of specific transmissions, ATP transmission rebuild kits typically include the following parts:
-Overhaul Kits – Gaskets, seals, o-rings, pan gasket, rubber lip seals, metal clad seals and sealing rings
-Banner Kits – Friction clutches, gaskets, seals, o-rings, pan gasket, rubber lip seals, metal clad seals and sealing rings
-Master Kits - Friction clutches and steel plates, gaskets, seals, o-rings, pan gasket, rubber lip seals, metal clad seals and sealing rings
-Master Plus Kits - Friction clutches and steel plates, gaskets, seals, o-rings, pan gasket, rubber lip seals, metal clad seals, sealing rings, common bushings, transmission filter and modulator (where applicable)
ATP Automotive transmission rebuild kits feature premium clutch material for smooth shifting, load stability, and high wear resistance, and steel plates that are manufactured to precise measurements for seamless installation and shudder-free performance. In addition, the gaskets, seals, and o-rings are exact-fit replacements. The parts are vacuum packaged to porous boards and sealed to ensure all components arrive complete and uncompromised.
Check if we have a rebuild kit for your vehicle under the “Transmission-Automatic” category in the RockAuto.com catalog.
And don't forget forum members get a discount code which can be used on as many orders as you like until it expires!
5% Discount Code: 0DA04C136736E7
Expires: August 6th, 2015
Please enter this code in the ‘How Did You Hear about Us’ box to receive discount. Please note that orders using discount codes must be placed online and the discount code must be entered before an order is submitted to receive the discount. Phone orders are not eligible for discounts.
If you have a question about parts or an order, please visit our FAQ and/or Order Status & Returns page, or send us an email at [email protected].
1 - 1 of 1 Posts
