Hi
Thanks for the replies.
We purchased this, as far as we know it is not a clone
click to close CARSOFT BMW PC Based Diagnostic Scanner OBD 2£59.951Click to view Full Size
Car diagnostic scanner code reader
BMW CARSOFT DIAGNOSTIC INTERFACE
OBD-2
New updated firmware '08 model
Complete System PC Software Supplied
3, 5 and 7 series:
E30 E31 E32 E34 E36 E38 E39 E46
E53 E60 E61 E63 E64 E65 E66 Z1 Z3 Z4 Z8
Complete PC based diagnostic system for your BMW. Do what your main dealer does when you take your car in to have a problem diagnosed without the cost. BMW dealers currently charge £100 an hour plus for labour, don't be at their mercy. Diagnose it yourself! We supply everything you need to get going.
1. Full system diagnostic test: Providing a complete overview of the health of your car.
2. Digital signal testing: Giving detailed information of all the control units. Any stored errors will be shown in a printable report with information to eliminate the error.
3. On supported models ('95 - '04): Service interval reset, component activation, live data, LCM reading, synchronise EWS and ECU adaptation values and coding.
4. Examine and erase all fault codes, ECU information and repair information. Live data and coding also supported.
Petrol Engines: All engines '98 to '04
Read & Erase all Faults Codes
Detailed Repair Information
ECU Information
LIVE DATA
ECU CODING
ADAPTATION
Smooth Running Test / Injector Test
EWS Synchronization Service Interval : All systems '98 - '04
Service Light RESET '98 -'04
Service MANAGEMENT '95 - '04
Reading of Days since last service
Reading of Fuel Consumption since last service
Programming of next Service / Inspection
Diesel Engines: All engines '98 to '04
Repair Information
ECU Information
LIVE DATA
ECU CODING
ADAPTATION
EWS Synchronization Brake & Traction: All systems '98 - '04
ECU Information
AIRBAG: All systems '98 - '04
Repair Information
ECU Information
ECU Coding HKL AIR CON: AIRCO systems '98 - '04
CIS Detailed Repair Information
ECU Information
ECU Coding
BC / MID Onboard computer multi info displays '98 - '04
ECU Information
ECU Coding
EGS: Electronic Gearbox System '98 - '04
Repair Information
ECU Information
DWA: Alarm systems '95 - '04
ECU Information, Alarm Activation Counters
ECU Coding
EWS : All immobilisers '95 - '04
ECU Information
SYNCHRONIZATION with ENGINE ECU
IKE: Instrument clusters '91 - '04
ECU Programming '95 - '04
Change Time indication 24/12 hours scale
Change Language indication 9 different Languages!
Coding of Steering Wheel Buttons set.
Change Temperature reading Celsius to Fahrenheit and back
IDrive Coding
Change of Date, Time, Brightness, Languages Settings, Units, Steering Wheel Buttons RPA Settings.
Coding of PDC Settings, Light Settings,Power Lock Settings
ALSO COVERS:
AIC – Automatic Interval Control
RAD – Radio
NAV – Navigation System
ZKE – Central Body Electronics
LRA – Automatic Headlight Vertical Aim Control
BMBT - On Board Monitor RDC – Tyre Pressure Check
MFL – Multi-Function Steering Wheel
VID – Video Module
EHC – Electronic Height Control
FGB – Rear Compartment Blower
SRS – Supplemental Restraint System
FREE STUFF!
BMW TIS 3 DVD SET
07/2006 TIS (Technical Information System)
08/2007 EPC (Electronic Parts Catalogue & prices)
09/2007 WDS-12 (Wiring Diagram System)
RRP £29.99
COMPLETELY FREE OF CHARGE!!
02032399312
ORDER LINE
ALL ORDERS DISPATCHED WITHIN 48 HOURS
WE AIM FOR NEXT DAY DELIVERY
The link for them is:
http://www.arcadia-in-car.net/index.php?osCsid=ghtrfl9otmsocd5sp1upigoai0ranhuo:
We have tried emailing them through their ebay site as well with no luck and no response.
We paid by debit card.
We have tried the link supplied to see if the company is still trading but no sure how to use that.
carychris
