My driver side window only open and close with each single click. It only move up and down inch by inch with each click. The anti trap warning is on. I’ve tried to reset the anti trap but it still don’t work.
Does this mean the regulator/window motor needs replacing? Is it straight forward to replace the regulator/window motor? Will I need to code anything or is it straight swap when replacing the motor?
Vendor
Which model and year do you have
If it’s a e60 then the window with need to be reset
BW chiptune
-Tuning BMWs since 1991
-Dyno Dynamics rolling road.
BW autorepairs
-Over 30 year repairing BMWs.
-BMW Ecu repairs.
-EGR programmed to stay closed all the time
-40% of my work is repairing the problems that are caused by other tuners Remaps
UK
0208 561 1818
07831 103030
Unit 8&9
alpha industrial estate
Clayton Rd
Hayes
Middlesex
UB3 1BB
or
Spain
Orihuela Costa
+34643890040
+447831103030
