My driver side window only open and close with each single click. It only move up and down inch by inch with each click. The anti trap warning is on. I’ve tried to reset the anti trap but it still don’t work.
Does this mean the regulator/window motor needs replacing? Is it straight forward to replace the regulator/window motor? Will I need to code anything or is it straight swap when replacing the motor?
I would suspect it’s more likely a problem with a module as anti trap is usually controlled by seperate module and not the motor itself.
Not sure which module though poss FRM?? I know on r56 mini it’s common for window issues like you are having and that is solved by a software update to one of the modules.
