I never notice drips under the car now when the air con is on. Where does the drain exit the car does anyone know? Thanks all!
Moderator
You won't get much out of the drains in the current weather conditions! The drains exit above the gearbox and can make you think you have a gearbox leak - the source of the drains are two rubber-couplers - you can see one just above my thumb here:
The rubbery bits can be manipulated so you can get some strimmer cord down there if you think it is blocked. Less water from the A/C system can also be attributed to a weak A/C system - especially a system that is low on refrigerant pressure.
