1 - 9 of 9 Posts
Hi,
I have an intermitant problem with my wipers. One minute they work fine and the next not at all ! The wipers never stop working half way up/down the screen, only when they come to rest at the bottem. the water still squirts when they r not working. I sometimes have to switch the engine off wen i am driving the car because it seems to reset the wipers and then it works again for a while ! The wipers have the speed sensor setting. I have been told 3 different things. An Auto-electrition tested it but as it was working at the time, he found nothing wrong !
One of the things i was told was a control thingy behind the drivers dash board... £300 but this was after being told it could be something else !
Now im just confused and do not have money to burn !:confused
Thanks Max
It could be a faulty wiper module. This is located behind the panel on the underside of the dash above the driver side foot well.
If it is not there, on later models they moved it to behind the glove box:thumbsup
IIRC it's a black unit with a blue section where the wiring goes in:D
Wow thanks,
That makes more sense now, i was told that... by the one of the people who guessed the problem, but i he said it was behind the glove box.
The thing that i was quoted £300 for was what you said. I think i will need to get a secondhand one !
Is that the proper name for it ? and now i need to find out which one it is !
Thankyou :thumbsup
BFuk Legend
Ill post the part number and pic of the location on mon for you mate. Had to do mine a couple of weeks ago. :thumbsup
Discussion Starter · #6 ·
Thanx Steve, that would be great !
Did you buy new ? if so did it really cost that much ?
Maxine :thumbsup
On my 1992 318is it was on the driver side closest to the door and when I did my engine conversion 1995 M3 I noticed they had moved the location to the passenger side behind the glove box:thumbsup
If you PM me the last 7 digits of the chassis number I will search out the exact part number for you as different models and years differ from time to time:thumbsup
1 - 9 of 9 Posts
