Hi, I am currently having problems with my 5 series diesel. The battery has been running flat overnight and I have found that there is a drain of 5-7 amps even after the interior lights etc have turned off. During the drain a fan can be heard running from the passenger wheel arch area.the fan stops if the bonnet/doors are slammed shut but can restarts if they are slammed again. Aquick search on google shows that this ia a fault other people have had but I canno find a sensible answer to the problem? Before I start stripping the wheel arch I was hoping one of you guys could point me in the right direction? I would assume that it is the heater fan running but I would have also assumed that the heater fan is situated behind the centre of the dash?? I have seen mention of an auxillary fan but am unsure what this is??
Any help will be greatly appreciated
Many thanks in advance Sam
